Sportsman 500 Issue
Old Jan 4, 2008 | 03:37 AM
chevyman142000's Avatar
Default Sportsman 500 Issue
So, went out with a friend from work this evening as the snowmobile trails finally opened to ATVs here in Wisconsin today. Round trip we put on a little over 70 miles. I'm absolutely frozen right now. Need to dress warmer next time for sure! Well, was driving down a trail and had her wide open. As I was slowing down I heard something that was not normal. It sounded like something was under the plastic where the belt goes. I figured the belt was about to break on me. Somehow made it all the way back home. As soon as I pulled in the driveway it got louder and then all of a sudden the noise went away. Now it seems to be fine. Any ideas? There must be something going on, maybe the explains why it creeps when I put it into gear?? I finally got the idle adjusted and it still creeps. Any ideas would be great. I plan on tearing into this soon, probably this weekend.
Thanks!!!!!!!!
Jeff
Old Jan 4, 2008 | 12:25 PM
BikKat's Avatar
Did it sound like something was hopping around on the belt? Could be a piece of the belt broke off and is just bouncing around in there, or better yet it was loose and banging around in there and when you got home it finally broke off, I would take off the clutch cover and see what is in there, and check the condition of the belt while you are at it :-)
Steve
Old Jan 4, 2008 | 12:41 PM
Well, if it was a piece of the belt, I should probably replace it regardless right? Should I get this from a Polaris dealer? Or is there a place on the Internet that is less expensive? Also, could it have something to do with the clutch stuff? I know nothing about them.
Old Jan 4, 2008 | 02:43 PM
Mongrol's Avatar
"Official Site Skeptic"
Where ever you buy it, stick with Polaris. Probably the best belt on the market.
Old Jan 4, 2008 | 05:28 PM
Hotdogmb's Avatar
Do you have EBS on your 2001?? If so it could be the EBS bushing on the primary clutch thats causeing the creeping. That is what happened on my 2002. It gets old and with the belt riding ontop of it will make it creep. I changed and lubed my and all was good. As far as the clunking noise in the belt cover, my guess would be ice build up. You ingest snow in the clutch intake then down to the nice warm cover area and bingo you get some ice build up. I think Mongrol talked about a pre-filter for the intake on Trackshare.com. Hey Mongrol, your on as many sites as me!! LOL
Old Jan 4, 2008 | 05:43 PM
Mongrol's Avatar
The more sites you hit the more you can learn!! I've cut back to this site and Trackshare.com because of intelligent discussions. Some of the others are pretty juvenile.
Old Jan 4, 2008 | 07:22 PM
Thanks guys! You are all great! I ripped her apart and found that the belt is bad. The guy I bought it from happened to have a spare so I'm going to throw that one on and see how she runs. As long as I have it apart, I'm gonna take the air compressor to it and clean her out. Hopefully this fixes my issues. I'm gonna guess this is the original belt.
Thanks again!!!
Jeff
Old Jan 4, 2008 | 10:17 PM
BikKat's Avatar
Be sure to put the belt on so you can read the writing from the left side of the machine!
Steve
Old Jan 4, 2008 | 10:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you buy a new belt buy the 700 belt as its a top cog and helps keep it cooler. if it is still creeping the bushing in the clutch needs replacing.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
