Polaris Sportsman 700 belt slapping cover?? Help
I have an ‘05 sportsman 700 efi thats having belt issues. It started when i was using it in low range, i was on it pretty hard til i came to a stop and it started creeping at idle, like the belt was trying to engage, kind of made a slight knocking noise too. It was also very hard to change gears. I cut the machine off, cranked it up again and the creeping/knocking went away and it rode fine the rest of the day. Then recently the belt started making a bad slapping noise, sounds like its slapping the clutch cover. Doesn’t do it at idle, only when throttle is applied, louder when it’s in gear and throttle is applied. I’m thinking it’s either a bad primary clutch or belt??? What do you guys think??
