2014 Honda Recon electric shift stopped working
Old May 7, 2020 | 06:39 PM
Yamonsz4's Avatar
Default 2014 Honda Recon electric shift stopped working
I have a 2014 Honda Recon ES 2 wheel drive I just replaced the Shift Sensor and the electric shift still won’t do anything.
I can use the shift bar and manually ride it so the transmission is good.
what should I replace next?
whata the change of me getting a bad shift sensor from the Honda dealership?
What should I do next?
thanks,
Larry
Old May 9, 2020 | 07:14 AM
Honda did send out a batch of bad sensors, but that was 10 years ago, they had "made in Mexico" written on them. Is a fault code coming up on the dash? After manually shifting, it will throw a code, but if, as soon as it fails to shift electronically, a Morse type code comes up on the gear display, what is it? In truth the most likely thing to go wrong is the shift motor. I rather think that motor is a pig to get back together though.
Old May 9, 2020 | 07:46 AM
Yamonsz4's Avatar
I bought a new battery but haven’t put it in yet I may need to go ahead and install the new battery then check and see if replacing the sensor worked.
Old Jun 4, 2020 | 08:15 AM
Blackneons24's Avatar
did you find out the problem?
Tyler658
Mar 11, 2012 10:09 AM
McNabb100
Dec 25, 2010 09:43 PM
Aahhyes68
Jul 23, 2008 09:39 PM
Blaster2005
Jul 10, 2005 11:05 PM
ChopperBill
Sep 6, 2000 09:42 PM
