China Quad Gear Box Help
Old Jun 24, 2020 | 11:31 AM
Quad nerd's Avatar
Default China Quad Gear Box Help
Hello, I have a 2006 redcat VX 150 with a gy6 150cc engine that has forward and reverse on it with a lever by the key. The lever is is hooked up through a cable to a gear box in the back. I was wondering, does this gear box have oil in it, and if so, what type? I haven't been able to find anything online and any help would be appreciated!​​​​​​​
Old Jun 25, 2020 | 02:13 AM
When faced with a gearbox, and no information about it, I assume it is going to be like others. If there isn't a level plug, remove the filler cap and use a wire rod as a dipstick to check oil level. Normally the level is roughly the bottom of the axle shaft. If it seems low, check the oil's thickness and smell it, gear oil smells distinctive, and is usually thicker than engine oil. It will probably be either gear oil or engine oil, the viscosity isn't that important. Not often such boxes need topping up anyway. I would do something with the breather, it is quite big and the dirt round the box shows that some will have gone down the breather. A piece of pipe going upwards and ending pointing down (so rain can't get in) is the usual, though a Suzuki style "concertina" would be neatest in that application.
Old Jul 1, 2020 | 08:47 PM
Quad nerd's Avatar
Thanks for the advice, I will try to use a wire as a dipstick to measure the oil lever. Before I open the gearbox up, are these gearboxes supposed to be filled completely with oil?
Old Jul 2, 2020 | 01:54 AM
No, as I wrote above, usually the oil level is about the bottom of the axle shaft. That is why you need a dipstick to check.
Old Apr 24, 2023 | 10:38 PM
beebee10's Avatar
does anyone know where you can gets parts for this theres a part on the the chain aide thw goes into the gear box that allows ot to move an its broke. i have no idea what its call an cant find a manual to find the name of the part an really dont want to spend 2000 on a new gear box
Old Jan 14, 2025 | 02:05 AM
Pxtrix's Avatar
Default Help
U don’t need to spend 2000 and I have two quads of the same and one it’s engine does everything with gears I can send you the whole part I can show you some images
robert301972robert
Jan 27, 2023 02:59 PM
Ricky Bennett
May 7, 2020 11:26 AM
MPDano
Jan 24, 2020 10:23 AM
Bill Hilly
Jan 1, 2020 10:01 AM
Robo5
Oct 4, 2015 05:37 PM
