Trx90ex bogs under throttle
Old Aug 2, 2020 | 01:37 PM
ckemp2011's Avatar
Default Trx90ex bogs under throttle
2008 Honda Trx90ex Boggs under throttle only with petcock in ON & RESERVE....when set to OFF fuel starts running stronger and stronger until runs out of fuel..,carb and gas tank already cleaned and new spark plug and air filter....and new 93 gas put in tank
any ideas??? Call or txt 8505120006...
charles
Old Aug 3, 2020 | 02:00 AM
As the fuel level in the carb drops, the mixture gets weaker, so it looks like your mixture is set too rich. Could be float level too high could be choke stuck partly on, or blocked air filter, could be too big a main jet or the jet needle set wrong. check the plug colour after running for a while with tap open, a sooty plug will confirm it is one of the above faults.
Old Aug 3, 2020 | 09:09 AM
ckemp2011's Avatar
New spark plug shows jet black....carb float is level with side of carb at 45 angle...took air filter out and everything is clear between carb and air box ...choke is not sticking and works correctly...
I did originally when I took carb apart for cleaning dremmel out the pilot (slow) jet ...I couldn’t get one of the small electrical wire strands thru it..,bit size was 1/32 and then 3/64...u can see thru the pilot jet if u take it out and look thru it ..could this cause the bogging under throttle...
not matter what I do with idle screw or air screw ...it doesn’t effect the problem either way...still bogs under throttle
Old Aug 4, 2020 | 01:27 AM
I would expect a Dremmel to totally wreck any jet you use it on. I never use anything but compressed air to clean jets out. Fit new main and pilot jets.
Old Aug 4, 2020 | 04:25 PM
ckemp2011's Avatar
thanks for the reply...I was thinking also ...the local Honda dealer tech looked thru them and agrees also...new pilot and main jet on order..
Old Aug 6, 2020 | 06:25 PM
ckemp2011's Avatar
New pilot and main jet and it runs very strong ...no bogging...
thnx
RFclipse
Jul 23, 2020 02:34 AM
jpn800
Jan 13, 2009 07:14 PM
awhondaboy
Jul 3, 2008 07:35 PM
backtrailboy2332
Oct 5, 2007 06:44 PM
edean37
Jul 15, 2005 04:48 PM
