90cc Chinese quad won't keep running
Old Aug 19, 2020 | 08:21 PM
kidsQuad's Avatar
Default 90cc Chinese quad won't keep running
It starts right up with the choke on, and when I turn off the choke it revs up a little higher, then dies out after a little bit. Any ideas?
Carb is cleaned out btw
Old Aug 20, 2020 | 03:11 AM
"Carb is cleaned out btw"
Not well enough. If it runs on choke but won't without, it is running lean, partly blocked jet or float level wrong are probable causes. An air leak into the inlet manifold is another possibility.
Old Aug 20, 2020 | 05:37 AM
kidsQuad's Avatar
Thanks for the ideas, I did run wire through every hole and jet possible in the carb within the last week. I bought the carb new less than a year ago and it never really got dirty inside. I just tried adjusting the float but I may try that again. Any more and I may have gas free flowing out of it, but I'll try. I put a new gasket on where the carb meets up to the intake so there shouldn't be an air leak there.
Old Aug 20, 2020 | 06:14 PM
kidsQuad's Avatar
tried adjusting the float a tiny bit more and as expected, gas started draining on the garage floor. So i have the float set decently. when i sprayed starting fluid at the air filter it would keep running btw
pjgorman85
Apr 20, 2015 09:32 PM
bdt
1) Engine problems..
19
Jan 28, 2012 01:10 AM
coffeepotbend
Mar 10, 2010 11:09 PM
jtbel
Sep 23, 2007 07:32 PM
