Lt80 smoking a lot ... previous owner mixed 80 :1
Old Nov 9, 2020 | 06:42 PM
Doom's Avatar
Default Lt80 smoking a lot ... previous owner mixed 20:1
Any way to cut back on the smoke from the tail pipe ...I’m running 40:1 ...previous owner was mixing 1 quart to 5 gallons ...wtf...I’ve only gone through about 4 full tanks on the lt ...smokes the most out of my banshee ktm 300 and ktm 50 ...rides fine though
Old Nov 10, 2020 | 07:43 AM
LT80's Avatar
LT80 Expert
Try burning out the pipe.
Old Nov 10, 2020 | 09:31 AM
Doom's Avatar
this was already done about five rides ago. When I had to put on a OEM exhaust for a spark arrestor
Old Nov 11, 2020 | 02:27 AM
Is the oil injection system still working? Some owners add oil to the fuel as well "just in case" but if it is working and you add oil at 40 to 1 as well, you are actually getting about 18 to 1
Also 2 pints in 5 gallons is 20 to 1 not 80 to 1 are you sure you are working your mix out correctly? The correct mix is about 30 to 1
Old Nov 11, 2020 | 07:18 AM
LT80's Avatar
LT80 Expert
4oz to a gallon... 32:1
Old Nov 12, 2020 | 10:59 AM
Doom's Avatar
... i use a special mixing cup. So there’s no way I’m messing up on the mix ... I have all two strokes and I mix one big batch of 40:1 for all of them ,and I’ve been doing that for a long time... The oil injection has been taken off. The previous owner said he was mixing one 1 quart to 5 gallons ... I believe half a quart is 40:1 to 5 gallons.... The LT 80 is so bad when we trail ride we always put it at the end because it stinks really bad to be behind. But this thing absolutely rips will take my 240 pound *** all over.
Old Nov 12, 2020 | 11:04 AM
Doom's Avatar
I run all my bikes 40 to 1. I was making special batches 32 to 1. For the LT 80. But switched to 40 to 1 so I didn’t have to make extra mixes and because it was smoking so bad.
Old Nov 12, 2020 | 11:32 AM
Doom's Avatar
I meant to say he was mixing 20 to 1 ... you’re right too much oil. Trying to type these questions while I’m in a hurry at work sorry
Old Nov 13, 2020 | 02:32 AM
Right, if you are not putting too much oil in, but getting too much smoke out, only two possibilities, either it is running too rich, clogged filter, stuck choke, wrong jets, etc, or the smoke is old oil burning off in the exhaust. Personally I would rather see too much smoke than too little, as a sooted plug is the result of too much oil, whereas a seized engine the result of too little.
yagerzzz
May 8, 2015 10:00 AM
TooFastIsBarelyEnough
Sep 20, 2004 04:04 AM
1988
Mar 24, 2004 02:19 AM
confusedbuyer
Jan 29, 2004 12:11 PM
mojavez400
Jun 21, 2002 11:30 PM
