1988 Suzuki LT230E Quad Sport
Old Nov 17, 2020 | 04:17 PM
gregferree@gmail.com's Avatar
Default 1988 Suzuki LT230E Quad Sport
Hey guys needing a little help.
My 230 will start fine but once half into the throttle it starts misfiring and cutting out. Thinking it's something electrical and have tested the stator was shows good. Could it be the CDI box? If so, my dealer says the OME has been discontinued and no aftermarket option. Have any of you ran into this issue before and what did you do?
Thanks
Old Nov 18, 2020 | 02:57 AM
Fit a new plug. If that doesn't cure it clean the carb out, far more likely to be this than electrical problems. If it still gives trouble, it is still more likely to be coil or stator than CDI.
No idea why as, in theory, the whole charging/battery system should be completely separate to the ignition circuit, but an overcharging regulator can cause misfiring. Check that the voltage doesn't go above 15v across the battery, with engine running at various RPM.
Old Nov 19, 2020 | 09:38 AM
Thank you for the reply. I'll try those options.
Kodiak01
Oct 5, 2001 12:39 PM
ltracerx
Jun 18, 2001 11:21 PM
powerslide
May 3, 2001 03:15 PM
ltracerx
Apr 27, 2001 12:19 PM
