Raptor 200 problems
Old Feb 4, 2021 | 02:35 PM
Dhdave's Avatar
Default Raptor 200 problems
Hey, my son just got his brand new raptor 200. The thing fires up right away, but it will idle for warmup and after a while it will stall, it can take anywhere from 2 to 5 min.
It does it too when riding and coming to a stop.
So what I did was to turn the idle screw clockwise a few notch and it seems to have helped, but it will do it almost everytime after hitting the reverse. The idle is almost to the point where you dont have to hit the gas to get the clutch to engage..
It literally brand new so..should I just be patient enough to get it to break in or? I dont like to see my little man all proud of this thing and he keep stalling everywhere when his friends dont lol.
My second problem is the display, it shows an error code and it wont show anything else, C-1850 is the code, any idea?
Also, i noticed two black cable not connected to anything in the electrical box, one looks like an antenna, wich make sense because i have a remote for it, but the other one with the crimp on?
Thanks, would take any advices !
Old Feb 5, 2021 | 04:01 AM
Contact the dealer who sold it to you they should at least know what error codes mean. The idle problem could be a partly blocked idle jet or idle mix not set properly at the factory. Change the plug first, you never know. If that doesn't work, and cleaning the carb out doesn't fix the problem, altering the idle mixture a little at a time, may work.
Old Feb 5, 2021 | 05:12 AM
Dhdave's Avatar
Thanks will look into it for the idle. But for the code i contacted the company that sold it to me and they have no idea, they dont know the machines at all.. they even make me call their supplier who dosnt know either. I will have to call in china lol.
They at least sending me a new display.. i doubt its faulty but who knows..
Old Feb 5, 2021 | 10:09 AM
Dhdave's Avatar
Any idea where is the mixture screw on these? Some sites say its pz27 other pz30, ive look all around and cant locate it.
Old Feb 6, 2021 | 03:19 AM
Usually under the front of the carb, often blanked off. This is to stop you messing with it so don't unless you have already tried the other fixes first.
Old Feb 6, 2021 | 06:27 AM
Dhdave's Avatar
yeh we rode it few times and it feels like it takes forever to warm up, but once it is, its running good. So I guess its just the way it is.
Old Feb 19, 2021 | 08:37 AM
Dhdave's Avatar
Default Mixture screw
Is the mixture screw behind that big brass cap on the left or behind the smaller one just underneath? It idle good but stall at anytime, warm or not.
Old Feb 20, 2021 | 03:28 AM
Usually it is actually under the carb, however, just checked the net and it looks like the small brass plug covers the screw https://www.pinterest.de/pin/327918416620460158/ the bigger cap covers the end of the throttle spindle.
Old Feb 20, 2021 | 05:26 AM
Dhdave's Avatar
thanks! This diagram is just what i wanted.
Old Dec 27, 2021 | 02:10 PM
Jerryk's Avatar
Any luck with the c-1850 message? I just got my son a raptor 200 and it’s doing the same thing. Also we have to give it a lot of gas to get moving, is this normal?
Jcrawford
Feb 26, 2015 07:36 AM
harrisonhunter
1) Engine problems..
Aug 12, 2013 04:04 PM
