03 Foreman 450ES shift switch
Old Feb 4, 2021 | 07:34 PM
Don Haessel's Avatar
Default 03 Foreman 450ES shift switch
Hi guys, my 03 foreman was just rebuilt
I can use the Manuel shift through all gears
when I try the shift up, nothing happens.
when I try the shift down, my lighting turns off.
When I push it. Few times I loose the fuse.
new angle sensor and no codes flash.
many help would be great.
Old Feb 5, 2021 | 03:48 AM
Depends what you mean by "rebuilt" if you had the engine apart, does the gearchange switch work properly, i.e. neutral light on when in neutral and display showing N, ditto reverse. Check all those wiring connectors you had off when doing the "rebuild"
Old Feb 5, 2021 | 08:59 AM
Thanks for the reply.
The motor was apart. I had an issue with aligning the n position switch at first. I fixed that and all lights and gears work. I have it running and can ride it with only the manual shift.
I am in the process of going through the connections. I have also tried to swap out the brain and that didn't change anything either.
It sounds like there is a connection issue with a couple of pins potentially in contact.
Old Feb 6, 2021 | 03:09 AM
More likely a wire close to one of the plugs shorting out on the frame or another wire. When you take wiring plugs apart, you move the wires near to them and a fault that may have been there for years suddenly becomes a problem. Had a 350 last week, wouldn't spark, started checking the wires at the CDI and noticed some wires just above the CDI plug had fretted through, against a rubber breather pipe of all things, water had got in and turned two wires to verdigris.
Old Feb 7, 2021 | 10:20 AM
Well, after I did some tracing, I had ran the 2 connections for light and the shift were backwards...
i noticed the colour of the wires against the diagram.
So, hopefully this can help someone in the future
Had the connections here backwards This would explain the reason for the lighting
Boff
Jun 26, 2014 10:09 AM
Kellielaiche
Feb 2, 2013 09:55 AM
warrior1989
Utility ATVs
Oct 22, 2008 08:18 PM
Paintboss63
Feb 22, 2004 05:58 PM
VonHammer
Oct 4, 2003 12:37 PM
