Great Idle
Old Mar 9, 2021 | 10:43 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Default Great Idle
Have 2003 650 Rincon idles perfect but wont accel.When you press throttle to incease rpms engine coughs,backfires spit but wont go,I have changed carb from another running atv still same.adjust values[ was good] changed ECU from an running atv still same, inspect ignition timing at flywheel and it does advance when accel,new NGK spark plug,Engine cranks over like it out of time drags and backfire during starting but when atv starts idles great no misses just purrrrs.I havnt tore down to camshaft or cam chain yet because engine is quite no chain noise and values clearance is always same when inspect just wondering if anyone has had any issues like this before on the 650 rincon?Ever had the crankshaft chain gear spin on crankshaft?Thanks in advance.Engine has 2400 miles
Old Mar 10, 2021 | 02:43 AM
Had an Eiger with similar problems after a lay up. I also did all the checks that you have done. Turned out to be the exhaust blocked, no idea why, rodents or a baffle moved I guess.
Old Mar 10, 2021 | 08:18 PM
Loved
Community Favorite
Forgot to mention I removed exhaust no change
Jarrod McReynolds
Nov 3, 2014 09:15 PM
dwayne1981
1) Engine problems..
Jul 28, 2014 07:58 AM
kawiking
May 18, 2006 09:23 AM
iccky
Feb 16, 2006 10:27 PM
kendrickraptor
Dec 13, 2002 04:15 PM
