Rancher 420 shut off
Old May 17, 2021 | 08:11 AM
Lescouch's Avatar
Default Rancher 420 shut off
Was riding the 2020 420 and it shut off and will not start back it only cranks. I can hear a click when I turn on the key but can't really hear the fuel pump purge. Is the fuel pump a common problem with these bikes?
Old May 18, 2021 | 01:52 AM
Lots of "common problems" with EFI systems. There is a servo motor on the throttle body called the ICAV which fires up when you switch on, this is a lot louder than the fuel pump and should whir away for about 3 secs after you turn the key, as should the fuel pump itself, if neither are making noise you have a bigger problem than just the pump seized. Check the fuses, but it is probably best to let the dealer have the bike, especially if it is still under warranty.
vero125
Oct 8, 2019 05:07 AM
JDOwens
Apr 23, 2014 08:19 PM
bean_11_2000
Feb 19, 2009 10:16 PM
quiksillvur
Dec 6, 2008 11:02 AM
