What type of Oil to use in a 1994 Kawasaki Bayou 400 4x4?
Old Sep 11, 2021 | 09:33 AM
BRUCEBWP2's Avatar
Default What type of Oil to use in a 1994 Kawasaki Bayou 400 4x4?
I'm about to drain the oil and take off the cover to inspect clutch on my ATV and I've got Valvoline synthetic 10w30 to out back in it.
I've seen some people say that will work just fine while others day absolutely not you have to buy Kawasaki brand oil or ATV specific oil.
The service manual says
Can someone tell me if this will work or is there a special oil to use?
Old Sep 13, 2021 | 02:32 AM
As it says on your chart SE or SF quality. Any oil suitable for motorcycles should have this marked on the tin. Because the KLF400 has "wet" clutches like almost all ATVs and motorcycles, the oil hasn't to contain certain friction inhibitors. Check if the Valvoline tin has either "suitable for motorcycles" or SE or SF on it.
Old Sep 13, 2021 | 02:40 AM
BRUCEBWP2's Avatar
Alrighty, Saw another poster say SE and SF was a outdated term no longer used on oil products so wasn't sure about that.
What I've got is Valvoline synthetic high mileage SAE 10w30
Old Nov 2, 2021 | 08:39 AM
Lookfortony's Avatar
Is it the Valvoline ATV/Motorcycle oil? Walmart sells that for about $4.79 a quart.
I wouldn't just use car oil in it for the slight savings you get. If it messes up your clutches, you will be wishing you had just spend the $15!
Just saying...
Olliethesnowman
Sep 18, 2020 12:01 PM
quepasa69
Jan 20, 2011 07:25 AM
photoghog
Nov 30, 2007 01:20 PM
LoveRidinA220
Sep 21, 2005 08:49 AM
