Linhai 260 slow start
Old Sep 26, 2021 | 08:46 AM
rdnkmrn2000d@yahoo.com's Avatar
Default Linhai 260 slow start
Replaced clutch, low starts fine, high feels like it’s trying to start moving in 3rd gear. High, low, neutral and reverse are the gear selections
Old Sep 27, 2021 | 02:37 AM
I would guess you have assembled the variator pulleys incorrectly and the front pulley is not going out wide enough, or the back not going in far enough.
Old Sep 27, 2021 | 04:08 AM
literally popped off the nut, removed old clutch, put on new clutch and put nut back on. Front pulley wasn’t touched. Reason for replacing was the weight springs had fallen out.
Old Sep 28, 2021 | 02:34 AM
The word clutch has been misused by makers of variator drives for a long time, so I have no idea if you are referring to the clutch, which is centrifugal, or a variator pulley which makers insist on calling a clutch, but isn't. Either way, the pulley assembly and belt would have to come off and the rollers inside the pulley assembly could have got "out of bed"
Old Sep 28, 2021 | 05:36 AM
reason for replacement was clutch weight springs falling out, so I’m sure it was the centrifugal clutch. The variation pulley is the front one, it wasn’t touched more than getting the belt off, I compressed the clutch to make the belt drop and become loose enough to slide over the front pulley.
Old Sep 29, 2021 | 02:34 AM
There is another set of centrifugal weights, in the variator pulley, depends on design but, with no belt to hold them in place, some may have got out of their channels, so stopping the pulley from sliding in and out properly. Worth taking a look at it.
Sykwidit
Mar 31, 2013 08:28 AM
team_realtree
Jan 5, 2011 01:50 AM
cobby
Mar 21, 2008 03:41 PM
Capt. Bob
Feb 21, 2008 12:34 AM
Beefy400
Feb 16, 2006 05:46 PM
