06 Cat 500 TBX turn over but no start
Old Jan 4, 2022 | 07:29 PM
Tinkering's Avatar
Default 06 Cat 500 TBX turn over but no start
New to playing with Atv motors but pretty mechanically inclined. Motor turns over but won’t start. Pulled fuel line and cranked and have fuel, pulled spark plug and after weak spark, changed coil. Pulled off cover on stator and all looks well. Magnets are in place and case is clean so now I’m lost on what to check next. Not sure if CDI would effect this or not but any help is greatly appreciated.
Old Jan 5, 2022 | 07:19 PM
papa hogg scoot's Avatar
Loved
Community Favorite
weak spark?new spark plug?check compression?If you assist will it run?
Old Jan 5, 2022 | 07:37 PM
Tinkering's Avatar
Got it running. Turned flywheel a few times while I had cover off. Felt a bit tight at first but then got better. Got it back to TDC and reassembled. Put new plug and battery in and cleaned up some wiring and it started on second crank. Not sure if timing was out possibly but good thing is it’s running.
06oilcooledcat
Oct 2, 2019 06:22 AM
Atvguy79
Sport Quads
Aug 19, 2019 10:42 PM
Dodgefan14
Apr 19, 2008 11:15 AM
hendrixfd41
Jan 7, 2008 12:38 PM
wayoverpar
Jan 31, 2006 04:54 PM
