Polaris 50 bogs at full throttle
Old Jan 22, 2022 | 08:09 AM
danieljleach's Avatar
Default Polaris 50 bogs at full throttle
I have a polaris 50 for my kids that bogs out at anything past 1/4 throttle. I can typically fix anything. It feels like fuel delivering. A shot of carb cleaner at full throttle will bring it right back to life and it'll even keep going as long as I don't let off the throttle, but if you let off the throttle and then get into again it will bog and bog until it finally dies.
I cleaned the carb a bunch of times, thinking i missed something. Then I bought a new carb and it acts the same way with the new carb. Cranking the air mixture screw all the way in makes it run better, lifting the needle all the way up helps too. I tweeked the float so that it would fill up more and that helped too. Something is not right.
  • It has no screen or restrictor in the exhaust
  • the oil pump is not hooked up, I am running mixed gas. Would that make is so much leaner that it would act like this?
  • compression is good (3 cranks gets 90psi)
  • removing the air cleaner makes it run worse (they say is normal) but if I do, I can choke it with my hand and get it screaming around
  • It was better in summer... I knew it wasn't right all summer but it got the job done. Now it the winter, it is really bad.
  • Cold engine is better, likely because the enrichener is helping
  • Stator? doesn't seem likely to me.
  • Reed valves
  • Air leak? I tried spray carb cleaner all around and didn't help
What am I missing guys?
Old Jan 28, 2022 | 10:11 AM
nny's Avatar
nny
i think i read that your running oil in the gas did i read that right?
Old Jan 28, 2022 | 10:31 AM
Yep that is correct.
Old Jan 28, 2022 | 11:48 AM
nny's Avatar
nny
from what ive been able to find its a 4 stroke engine that your running like a 2 stroke. if im understanding, please correct me if im wrong. oil changes the burn rate of fuel which could mean that when you give it fuel your cdi is telling the plug to fire too early.
Old Jan 28, 2022 | 05:46 PM
It is 100% 2 stroke. There is zero doubt about that. It has an oil reservoir, injection pump and no crank case.
Old Jan 28, 2022 | 07:48 PM
nny's Avatar
nny
have you tried checking how much fuel is in the bowl. Your initial problem of bogging down sounds like your fuel bowl not filling up so when you give it gas it tries to pull from the bowl and coming up dry. Or your idling on the wrong circuit in the carb.
if your getting enough fuel out of the bowl when you drain it then adjust your Idle circuit and open a quarter to half a turn at a time.
Old Jan 28, 2022 | 10:06 PM
Yes the bowl is full. On these the air mixture screw controls air so opening it up leans it out.
Old Jan 29, 2022 | 11:33 AM
LT80's Avatar
LT80 Expert
CDI's are well known to go bad on polaris's.
Yes, 90 is good but did you max it out (spin more)?
Crank seal?
Plugged exhaust?
Old Jan 29, 2022 | 04:34 PM
Crank seal?
Plugged exhaust?
how do I check the crank seal? It did go higher than 90 but I don’t remember. I’m leaning towards rejetting it. Polaris dealer says they are all lean from the factory and with age they act up.
This guy says a voltage regulator mysteriously fixed his https://www.polarisatvforums.com/thr...-choke.193265/
if I unplug my choke so it runs rich all the time, it runs pretty good so I doubt it’s compression or reed valve related. Maybe a crank seal sucking air?
Tazzin
Technical and How-To Articles
Oct 11, 2021 02:49 PM
SlowSL
1) Engine problems..
Jan 30, 2017 09:04 AM
radarme
Mar 14, 2005 01:38 PM
URCRAZY
Jul 5, 2004 06:06 PM
