Hard turn over after chain issue.
Old May 5, 2022 | 09:44 PM
Captain84's Avatar
Default Hard turn over after chain issue.
Hey guys,
So I bought a 125cc taotao motor on Amazon and installed it on an electric golf cart after gutting it of course. Got motor in made shifter ran wiring. Its electric start, 3 spd auto with reverse. In the rear i installed a live axle. During my maiden voyage i was cruisin about 25mph and let go of the gas and the rear end locked up and it came to an abrupt halt. Guessing chain bound up because I used a tensioner, shouldn't of, now it turns over super hard even with new starter. It cracked the stator case a little but not enough to make the turn over issue. Was just fine before the incident. Everything seems sound and looks good. Can turn it over by hand so I cannot figure out the issue... HELP!
Old May 7, 2022 | 01:05 AM
Take the alternator cover off and the plug out, then turn the flywheel round by hand, if it doesn't spin easily, there must be a problem, probably with flywheel catching on something, my guess would be case bent onto flywheel. If you can't find anything wrong at flywheel side, but crank is binding somewhere, check for a problem at the clutch, by removing cover on that side.
Old May 8, 2022 | 09:45 AM
Zrock's Avatar
Super Quad Patrol
If you cracked the stator cover then something let go inside to do that... using a tensioner on the chain should have been no reason for the chain to bind up it would have the opposite effect. You are running a machine that is probably 4-5 x the weight of the atv it was designed for so the weight of the machine overcame the engine as now you have the weight of the machine pushing the engine, I would almost bet it forced the timing out. A gas golf cart set up uses clutching similar to a snowmobile or larger atv with a belt so it slips when you slow down and don't over come the engine..
Old May 10, 2022 | 08:33 PM
Captain84's Avatar
Default Again...
So after everything I hooked up cables to a car battery to try and get it started. Still cranked super hard and ended up melting a green wire. How do I go about fixing the timing issue if you guys still think that's the issue?
Old May 11, 2022 | 01:59 AM
Extremely unlikely to be timing. As I wrote earlier, take the plug out and the flywheel cover off, and find out why it is stiff to turn.I had a Suzuki LT50 recently that had thrown the drive chain and damaged the case next to the flywheel, when I took the cover off, the case was rubbing on the flywheel.
Dirty Red Neck
1) Engine problems..
May 31, 2021 12:45 PM
ozarkeun
May 13, 2009 12:13 PM
UtahRancherRider
Dec 4, 2005 08:26 AM
MHull
May 24, 2005 08:47 AM
Blazer250
Jan 7, 2001 03:26 AM
