Lt80 Wiring colours at ignition switch/key
Old Aug 31, 2022 | 03:31 AM
Lt80lmc's Avatar
Default Lt80 Wiring colours at ignition switch/key
Hi,
Bought a lt80 for my son recently.
I have a safety pull chord that I want to fit so if he falls off the bike will cut out.
I am looking to know what the wiring is around the ignition switch/key so I can splice in to fit the kill chord.
Current wiring is standard, so, red orange, black yellow, black white.
which wires should I break into to fit the switch?
thanks in advance all!
Old Sep 1, 2022 | 02:24 AM
Black/red (plugs into black/yellow at switch), and black/white, which is earth. Short them out and engine stops.
Old Sep 1, 2022 | 02:29 AM
Lt80lmc's Avatar
hi. So if I have safety kill chord which of the cables should I splice into so that when the chord is pulled the ignition is killed also? I don’t know much about wiring but can solder the 2 wires from the kill switch into whatever wires they need joined to.
thanks
Old Sep 2, 2022 | 01:43 AM
You need a safety cord switch that closes contacts when pulled, and solder one side to either black/red or black/yellow and other to black/white, or earth it.
Old Sep 2, 2022 | 01:49 AM
Lt80lmc's Avatar
great that’s exactly the type of safety chord I have. I will solder to black/yellow and black/white as you said.
Many thanks for your help merryman
gahunter33
Sep 30, 2016 08:39 PM
DAMONSQUAD
Apr 12, 2010 09:42 AM
dwshaff@sbcglobal.net
1) Engine problems..
Sep 18, 2009 10:12 AM
PolarisUK
Apr 23, 2005 05:22 PM
stevendsm95gst
Jul 4, 2004 02:25 PM
