150 ATV not starting
Old Oct 16, 2022 | 05:10 PM
rking949's Avatar
Default 150 ATV not starting
afternoon folks. the atv is turning over. replaced fuel filter, battery, and cleaned air filter. The only thing i notice from there is the green light on the dash (that should be on when in neutral) is NOT coming on. i have tried to follow the wire from the light but seem to get lost from there. Any ideas would be very helpfull.
150cc automictic Pentora
Old Oct 16, 2022 | 06:55 PM
djshad1469's Avatar
Have you checked for spark and compression?
Old Oct 16, 2022 | 07:11 PM
rking949's Avatar
Yes the spark is good.
Old Oct 17, 2022 | 02:28 AM
Some bikes give an extra strong spark in neutral to make starting easier, a bit like the old bias resistor system on car coils of the 1970s and 80s. This is worked from the neutral light circuit. However, if you are getting a decent spark anyway, I would be cleaning the carb out. Remove float bowl, remove jets and blow them and the holes they came from out with compressed air. If that doesn't work, check compression as djshad1469 suggested. Under 90psi and bikes get hard to start.
Ken13
Sep 19, 2018 02:04 AM
maverick97355
Mar 2, 2007 04:11 PM
vtwiner
Jun 23, 2003 02:01 AM
sandsurfer
Jun 2, 2001 10:46 AM
HELMET660
ATC 3-Wheelers
Feb 16, 2001 07:38 PM
