LT80 help please 🙏 I'm lost in the sauce
Old Aug 10, 2023 | 08:00 PM
drg1984's Avatar
Default LT80 help please 🙏 I'm lost in the sauce
So I got the starter fixed. Replaced the carburetor, changed spark plug, new gas, has compression. It will fire only for a second. If I keep the electric start pushed it will run kinda. Spay starting fuild into the plug hole it will fire run for a second then die. Help what am I missing that could keep this from running.
Old Aug 12, 2023 | 07:16 AM
Give the carburettor a good clean out, check the O rings are fitted to the manifold and try again. If it still won't start, check compression, LT80s often get run until the compression is too low to start, then put up for sale.
Old Aug 12, 2023 | 03:49 PM
drg1984's Avatar
Compression is good just released the carburetor still can't figure it out bout to post it up before I set it on fire.
Old Aug 12, 2023 | 07:40 PM
drg1984's Avatar
merryman I finally got it to run but it's only running with the choke on if i push the choke down it only runs while fluttering the throttle but if I disengage the safety it dies no matter what am I missing?
Old Aug 13, 2023 | 04:12 AM
"if I disengage the safety it dies"
No idea what you mean by that.
Give the carb another clean, remove jets and blow both them and the holes they came from out, with compressed air.
Old Aug 13, 2023 | 07:37 PM
drg1984's Avatar
The safety switch on the brake to start it. I got it running now but it's burning really rich and acts like it wants to take off push the throttle in and it goes no where but will move on its own with out the throttle being pushed.
Old Aug 14, 2023 | 02:48 AM
If it is revving too hard at idle, either the throttle cable is wrong or the idle speed screw set wrong. Check the cable, outers can come out of the carb top when you work on a carb and you need to be sure it is back down in the hole. Inners can be put in the slide wrongly. If the cable is OK adjust the idle speed screw so it doesn't try to take off. If it won't drive, check you put the pulleys etc, back together correctly. Not sure how you would tell it is running rich with all that oil smoke.
Old Aug 15, 2023 | 06:12 AM
drg1984's Avatar
There's alot of carbon build up after about 30mins of running so that's why I figured it was burning rich. Do you know what the factory adjustment is on the idle screw?
Old Aug 16, 2023 | 02:46 AM
Once the child is using the bike they are mostly off the idle jet. If it is getting too much fuel, try moving the circlip on the needle in the throttle slide. Drop needle down to weaken the mixture on the main jet.
rumblefish1973
Dec 28, 2025 04:34 AM
Kennytwo
Dec 18, 2015 07:07 AM
smokincigarettes
Mar 17, 2014 07:05 PM
yellow lt80
Feb 12, 2014 12:10 AM
cstrait37
Feb 10, 2012 11:51 AM
