Voltage drop at starter solenoid
Old Mar 30, 2024 | 07:34 PM
jonnyd91's Avatar
Default Voltage drop at starter solenoid
I replace the entire wiring on my 70cc atv with this:
Amazon Amazon
Everything was working fine but i wanted to then use the controls that came with the atv because they are integrated in the hand brake.
While i was wiring the starter switch i popped a fuse, replaced the fuse and put it all back together and now the starter button doesnt work.
When i put a volt meter on the 2 leads that go from the starter button to the starter solenoid and i press the start button, i get 12+ volts on the multimeter.
When I connect the solenoid and hit the button the voltage drops to around 4 volts.
What else could I have possible blown when i was re wiring the switch?
Old Mar 31, 2024 | 03:15 AM
Seems like you have a flat battery or one of the battery leads is loose, this includes earths. Could just be the ign switch to start button, to solenoid circuit, or brake light circuit, if that is wired into the starter circuit. Another possibility, starter or engine seized.
Old Mar 31, 2024 | 07:31 AM
jonnyd91's Avatar
forgot to note, I also jumped the 2 small wire to the solenoid direct to the battery and it cranks. I also attached a battery jumper to it and the button still voltage drops.
It’s just weird because it was working fine before the fuse popped.
Old Apr 1, 2024 | 09:45 AM
jonnyd91's Avatar
Well after ripping apart the brand new harness to isolate the starter circuit, i wont up tracing it back to the glass fuse that come off the battery that goes to the small gauge wiring.
The fuse did not look blown, but once I removed it and bypassed it with a screw driver, everything started working.
I ordered a blade fuse holder to replace the crappy fuse.
Benji675
Aug 1, 2021 02:45 AM
TnTom
Sep 26, 2016 01:40 AM
06cumminsman
Jul 21, 2016 02:17 AM
yzballa08
Oct 25, 2008 12:59 PM
R00ST
Mar 28, 2007 11:59 PM
