Polaris predator 50 brake switch and electric start question
Old May 1, 2024 | 12:48 PM
lph008's Avatar
Default Polaris predator 50 brake switch and electric start question
I'm working on a predator 50 and when I release the brake after I start it, the quad dies. Kickstart only works, previous owner said he replaced the starter and coil. If I unplug and jump the brake switch sensor, it will start with the kickstart and run but I can't get electric start to fire. Was wondering if maybe it has something to do with the brake switch.
Old May 1, 2024 | 04:20 PM
lph008's Avatar
I removed the starter and put 12v to it and verified that it does work but when i put it in machine and add my 12v , it doesn't turn over
Old May 2, 2024 | 02:09 AM
You need to get the wiring diagram. Sounds like someone has messed the wiring up. Bikes often need the brake light to be on for the start button to work but if it needs the brake to be on for the ignition, I would guess an earth wire is bad, but that is just a guess. Maybe the earth lead was connected to a starter mounting bolt (they often are) and previous owner left it off when fitting the new starter.
Old May 2, 2024 | 06:07 AM
lph008's Avatar
Yes I verified that the ground wire is connected to the starter and the starter does look new.
the wiring has definitely been messed with, the tether was removed also. Brand new battery and the horn works so im getting oower to the switch.
Theres a plug that isnt connected on the left side frame that is a green wire and a orange wire with a green plug. It's taped to frame heading towards the rear of the bike right after gas tank??
Old May 4, 2024 | 02:49 AM
Does the solenoid click when you press the start button with ignition and brake on? Afraid I don't know the Predator 50 so can't give advice other than generic. As I wrote above, get the wiring diagram and, if the solenoid isn't clicking, trace and test the start button and solenoid circuits.
Old Oct 6, 2024 | 09:14 PM
Farmerbrown91's Avatar
Default Find the solution?
Good evening - I have a predator 50 with the exact same issue… did you by some chance find what was causing the issue on yours?
Old Oct 7, 2024 | 05:06 AM
papa hogg scoot's Avatar
Loved
Community Favorite
I would check tether switch in center of handlebar
neegzoo4
1) Engine problems..
Mar 26, 2018 10:32 AM
Johnny821
Oct 22, 2016 09:11 PM
jabeu
May 9, 2012 03:18 PM
vetteboy86
Mar 13, 2012 09:57 AM
Liteshow
Apr 25, 2008 01:29 AM
