2006 LT-Z50 Parking Brake operation
Old Mar 12, 2012 | 08:40 PM
vetteboy86's Avatar
Default 2006 LT-Z50 Parking Brake operation
My daughters quad developed an issue last season. It starts and idles fine. However once throttle is applied it seems as if the rev limiter kicks in.
I've done some research and found that the parking brake assembly can cause this issue. To test, I attempted to start the quad without the parking brake set. It started. So I can start it without the parking brake set.
I removed the parking brake switch. When the parking brake is set, the switch is closed. When the parking brake is not set the switch is open. I can operate the switch using the plunger and there is no change in how the quad runs. I checked continuity back to the connector the parking brake wires plug into (along with the start button and kill switch) and the wires checked good.
So now I'm stumped. I could chase the wires further, but wanted to stop here first. If anyone has had further experience with this problem please let me know. Thanks in advance.
Old Mar 13, 2012 | 07:04 AM
vetteboy86's Avatar
I learned something else last evening. The quad will start with the pull starter no matter what position the parking brake switch is in. However it will not start via the electric start when parking brake is not engaged.
This still doesn't seem correct to me.
Old Mar 13, 2012 | 08:38 AM
LT80's Avatar
LT80 Expert
It isn't a carb problem? Sounds like a plugged jet.
Old Mar 13, 2012 | 09:57 AM
vetteboy86's Avatar
Yes, it could be a fuel delivery problem. I was pursuing the parking brake first, as I'm not 100% certain if it is operating correctly. From what I've found on this site, that whole system is suspect.
So is it normal that the machine starts by the pull rope regardless of parking brake status?
This whole situation stinks. I've owned 15+ fourwheelers over my life, and the one I purchase for my daughter has given me the most grief!!
Thanks in advance for the replies.
Ronk407NY
Feb 13, 2016 11:05 AM
sportsman2005
Technical and How-To Articles
Aug 19, 2015 10:52 AM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
