250cc Baja wilderness trail no power to ignition
Old Aug 17, 2024 | 05:36 PM
DelRio79's Avatar
Default 250cc Baja wilderness trail no power to ignition
Hello everyone, had a project dropped in my lap. Need some help please. As title states, I have no power to the ignition switch or the dash in general. Brand new battery, new ignition switch and no power to the front. Solenoid clicks when i put power to it and bike will turn over when i jump solenoid but I have no power. Any suggestions before I have to disassemble this thing and chase wires? Thank you in advance and have a blessed day
Old Aug 18, 2024 | 02:26 AM
Power goes from battery to main fuse then to ignition switch and voltage regulator. No power to ignition switch means main fuse gone, or that wire from battery to fuse, to ignition switch is broken.
Old Aug 19, 2024 | 01:15 PM
DelRio79's Avatar
Ok so this one goes from battery to starter solenoid then wires and fuse that goes to ignition switch. Have power to solenoid but not the the wires going to ignition and fuse is good
Old Aug 20, 2024 | 02:20 AM
Right, difficult to see colours on that pic, but the thicker wire in that multipin red plug will be the one going to the ignition, if there is no power on it there, the solenoid's fuse holder is broken. If there is power on it at the solenoid plug but not at the ign switch, the wire has a break in it.
Old Aug 21, 2024 | 11:07 AM
DelRio79's Avatar
Gotta be the fuse holder then. I can put power to the ignition wire at the plug and get life at key. Nothing at the blade. New solenoid ordered. Let you know when it comes in. Thank you for the assistance
Al-53
Jan 31, 2022 12:26 PM
ajduby
Oct 22, 2020 09:15 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
timtwig
Mar 27, 2013 03:26 PM
boola1341
1) Engine problems..
Mar 10, 2010 11:19 PM
