1985 200m decompression lever
Old Jan 22, 2026 | 04:54 PM
Jays200m's Avatar
Default 1985 200m decompression lever
Asking if the decompression lever is clocked improperly will that affect valve adjustment?
Old Jan 23, 2026 | 03:32 AM
Not sure what you mean by "clocked" Fairly sure the decompressor is a simple cam, working on the top of the rocker arm, with lever one way the cam is on a flat which doesn't touch the rocker, with lever t'other way, cam pushes rocker and valve down, letting compression out through exhaust valve. If you tried to set valves with decompressor on, you would have a very wide valve to rocker gap when you move lever to off.
Arsimmon
ATC 3-Wheelers
Apr 26, 2007 09:18 PM
wanaply21
May 10, 2004 08:52 PM
beechy
Apr 5, 2004 12:27 AM
N3C0T0
Sep 23, 2001 10:22 PM
quad1man
Jul 10, 2001 05:59 AM
