Can't hold air in tire
Old May 6, 2001 | 10:29 PM
ferd350CT's Avatar
I have a sram 500 with stock steel rims.They are all dented(not badly)but,one tire leaks from rim.It seems to leak from multiple areas around the seat or rim.I fill it,ride for a while,fill it again.Will slime work for this application?
Old May 6, 2001 | 10:31 PM
brokemybanshee's Avatar
It cant hurt to try...
Old May 6, 2001 | 11:44 PM
MagnumMudMan's Avatar
ferd
I have had good luck with Slime sealing slow leaks around the bead. Take the tire off the machine, put the slime in, and roll the tire around on end and on the side to make sure that the slime will get up around the bead. Air it up and it should hold air. Hope this helps.
Old May 7, 2001 | 04:51 AM
Traildog's Avatar
One other thing to check for is debris between the rim and the tire.
Old May 7, 2001 | 07:53 AM
TNT's Avatar
TNT
I had the same problem. Slime fixed it.
Old May 7, 2001 | 02:47 PM
Prospector's Avatar
Put a can of any brand of tire sealer in it and forget it.
You really don't need to remove the tire; but as soon as you put it in, go for a ride to make sure it gets well-distributed.
Jason Poulin
Sep 20, 2015 02:49 AM
toonces
Sep 5, 2015 01:14 PM
Sep 2, 2015 11:15 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
