'98 SP500 CDI box
Old May 21, 2001 | 01:31 PM
Binky's Avatar
After taking my bike on the back of my truck for two and a half hour trip I managed to get about 3 miles out of it when it just died,I checked the fuel,wiring connections grounds etc. and There is no spark. After getting it home I metered out the high tension coil and it is within the set numbers for resistance. So now I am wondering is there anyway to be sure it is the CDI box or is it a case of if everything else works then it's the CDI? If so does anyone know who would sell an aftermarket one? Any help is appreciated.
Old May 22, 2001 | 12:36 PM
Ruud400's Avatar
Binky,
On the same page in your owner's manual, you will also see the continuity check for the stator. Please do not overlook this. A good friend of mine has the same machine as you, had the same problem, and bought a new coil. This did NOT solve his problem. After we performed his continuity checks, we determined he had a short in his stator. Sure enough, once we had the flywheel pulled, on the stator one of the energizer coils for the CDI had melted a hole right through the wax and was causing the open. According to a local dealer, this is a common problem with the 98's. Check this as well before you waste money on a CDI.
Old May 22, 2001 | 09:03 PM
Binky's Avatar
Thanks Ruud I will try that next,I am using a clymer shop manual for 1985-1995 should this info be close enough?
Aug 21, 2015 01:46 AM
FireFighter
Jan 7, 2001 04:50 PM
alaskaweasel
Aug 24, 2000 08:49 AM
wilddave
Dec 5, 1999 06:41 PM
cstark
Sep 11, 1999 01:21 AM
