335 a pullin
Old May 21, 2001 | 01:48 PM
Deepcut5's Avatar
My sportsman 335 wants to pull to the right all the time. I'm pretty sure that it is not the right front hub locking. What else could it be?
Old May 21, 2001 | 03:05 PM
MagnumMudMan's Avatar
Deep
I would jack the front of the machine up and try to isolate the problem. Spin both tires and see if the right one seems to spin harder than the left. If it does, it is either the hub locking up or the brake grabbbing. If the right hub spins the same as the left, I would check the toe of the front tires. The right front may be towed out, thus causing the machine to pull. The tires should both be slightly toed out. You can adjust the toe by turning the tie rod ends. Also, do you have a lot of play in the steering. The right tie rod end may be going out, thus causing the right tire to wander out more than it should. Hope this helps.
Old May 22, 2001 | 01:17 AM
Dazed's Avatar
Check your air preasure that can cause weirde thing in the handling.
bbradford
Worst Stuck Photos
Oct 18, 2012 09:11 AM
Gurney
Jul 13, 2007 08:33 PM
fasterthanyou22
Jun 6, 2006 11:08 PM
BaD660
Dec 18, 2001 02:56 AM
