WARRIOR PLEASE HELP
Old Jun 3, 2001 | 12:02 AM
mudmanatv4x4's Avatar
Hi,
My brother has a 99 warrior. We can get it to start but it will bog and back fire a lot. This is everything we have done. Put in a new spark plug, cleaned out the carb, put fresh gas in, tried to tow start it, and some what checked the wiring system. He has a k&n filter, keihn 38mm. carb ,and white bros megalloy exhaust. We tested the spark it seemed week but was sparking. Everytime he hits the throttle it will backfire or bog and shut off.
please help if you can. All help is apprieciated
thank you very much.
Old Jun 3, 2001 | 12:35 AM
getoutofmyway's Avatar
You have covered most of the basics, so if it were me, I would take the carb apart one more time and make sure it is completely clean since you are getting some spark. I would also make sure you don't have an air leak between the carb and cylinder head, I've heard that the intake can crack and allow air to get into the motor causing it to run crappy. If its still no go after that I would spend my time on the electrical end of things. Change the plug again. Check all connections especially the grounds starting at the battery. Pray it's not a bad ignition module or pray you have a friend with a Warrior that will let you barrow his to test. Best of luck.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 3, 2001 | 07:30 AM
Dirtpig's Avatar
Be sure to check the park brake.......it has a switch on it that won't let the motor rev.........sometimes this switch will not release when the park brake is released, might need adjusting
Old Jun 4, 2001 | 01:22 AM
thank you for this help. i will try all this, and the other things one more time. But it sounds a little more then not being able to rev. I mean it cant rev, but it also runs crappy. when its idleing(such as backfire etc.) well thanks for this help and if you have any more info you would like to add please do so.
thanks again
Old Jun 4, 2001 | 01:30 AM
ltracerx's Avatar
Listen to Dirtpig. My friend put the parking brake on with is Banshee and it did the same thing too. Hope this helps you.
Old Jun 4, 2001 | 10:39 AM
sAyIt_fmf's Avatar
Ruff, lumpy idle.... If you have ruled out any carb/jetting problems...
then it sounds like your ready for a valve/timing check. Have you checked them lately.
If you jumped a tooth on your timing chain...theres your problem. Try not to run it until that is checked. You can damage the valves pretty bad.
Old Jun 5, 2001 | 01:26 AM
aright, thanks everyone. This is what were going to do and if i can have some help on this last question. We have a really good mechanic and he is not that expensive so we are going to bring the quad to him. With all the information i have given you, how many hours of work should we tell him to do? We usually give him a few hours max. and he will do his best to fix it.
thanks everyone for your help
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
