Toe-in or Toe-out? Utility trailer makes great alignment rack
Old Jun 18, 2001 | 02:22 AM
fourlix's Avatar
I was riding on a particularly squirrly piece of smooth graded forest service road with a layer of loose stuff right on top of smooth hardpack. I was thinking I had about a 1/8" of Toe-in. The baja DS had 1/8" of toe-out, I think. So I thought I'd take a look at the DS, using a tape measure, tire center to tire center, in front of the front tires, and at the rear of the front tires. Simple enough, having the adjustable TimmyBoy upper A-arms makes you very aware of your steering geometry.
But I had already loaded the DS on my utility trailer for a Father's Day ride. Then I looked at the DS on the utility trailer and said,"Hey Look, it's an alignment rack!". So using the frame rails of the utility trailer, I measured the toe-in/toe-out off of the utility trailer. Very convenient, very accurate.
So I changed the toe-in to 1/16" toe-out. Did a little smooth fast graded road action and, Oh, yeah, that's it. If you think about it, toe-in makes the quad go the opposite direction when you lean or move your weight from side to side. Toe-out makes you go right when you shift your weight to the right, etc. Just a tiny smidge keeps you going straight till you shift your weight. Very nice, very stabile, even in the marbley stuff.
HondaR24
Jul 23, 2015 11:22 AM
bradleyheathhays
Jun 23, 2015 01:30 AM
WilliamBos
Jun 11, 2015 05:57 PM
jayking232003
Jun 9, 2015 02:54 PM
bodini
Aug 28, 2000 10:27 AM
