slip on- White Brothers 'E': How many discs do you run?
Old Jun 27, 2001 | 02:30 AM
RotGutBottom's Avatar
I'm using all the discs that came in the basic e' series box. Should I be using MORE?
Old Jun 28, 2001 | 06:22 AM
Ash's Avatar
Ash
all that i know is that the more discs you run the better the flow of the exhaust. but to many discs may hurt performance. call wb and find out
Old Jun 28, 2001 | 09:26 AM
4wheelitis's Avatar
From past experience on a two stroke you would want all the discs in and jet occordingly, On a 4 stroke however you still want some backpressure there for it to run properly. I would install all the discs that came and see if you can jet it in to run its best. If you cant get the jetting right, take one disc out and try that, and so on. If I remember the more discs the more top end you'll have and the fewer discs will bring the torque curve down in the rpm range some. I used to change discs depending on tight woods or more open riding.
Old Jun 29, 2001 | 10:31 AM
400excaliber's Avatar
Good info guys! My question to this is: are you running the "s" bend, or the full meg? The performance of these pipes is quite a bit different.
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 29, 2001 | 04:22 PM
mt400EX's Avatar
call WB then tell us what they ahd to say, I am also interested. I might be getting the Pro Meg.
Old Jun 29, 2001 | 04:50 PM
hylton400ex's Avatar
i would try running without any discs, it seems to run a lot better for me. i also have a 162 main-jet, K&N, and took the air box lid off.
Old Jun 30, 2001 | 01:24 AM
str400ex's Avatar
more disc for top end less disc for low end
Old Jun 30, 2001 | 01:29 AM
str400ex- ...where did you hear about that? Is it a noticable difference when you remove all the discs?- (for bottom end)- why does it work that way?
Old Jul 2, 2001 | 06:30 PM
str400ex's Avatar
i had the pipe and the directions told you that although i didnt mess with it to much i just ran all the disc they gave me,since then ive went with a sparks x6 and i like it better
Pehter
Oct 3, 2024 11:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
