my kart
Old Jul 9, 2001 | 10:58 PM
YUKONGT's Avatar
hey i have a 5hp tecumseh motored red fox lxt one seater go kart i decided to rebuild and revamp the motor i would like to add an exhaust header cam carb pistons things like that i would like it to go a lot faster and its for offroad if i could get it to do a wheelie lol that would rock but my question is where and what can i get for it to make it high performance i dont know where u can get any parts i listed for that motor thanks [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 9, 2001 | 11:37 PM
ltracerx's Avatar
Get a Yamaha 100cc kart engine!
Old Jul 14, 2001 | 12:21 AM
yamahagye's Avatar
no offence, tecumseh engines are not the best. you could put a whole bunch of money in them but the engine would not last very long and all that money would go to waste. i've had 3 tecumseh engines. all of them wore out pretty fast. so i bought a briggs & stratton engine. it is still running and has already outlasted the 3 other engines.i agree with the previous post. get a purpose built race cart motor or atleast a different brand engine.
Old Jul 24, 2001 | 12:36 AM
guerryb's Avatar
Remove the governor. If you have a 5.5 hp Enduro motor, the only difference between it and the 7 hp model is the RPMs allowed by the governor. And, NO you are not likely to blow your engine as long as you use the torque convertor and have big rear tires. Other tricks - get a header, improve the airflow on the carb. You can get a kit for around $70 that has several performance changes that will push it to around 9 hp. Check out Off Road Gokarts at YaHoo.
The Yamaha KT-100 engine is a poor candidate for off-roading because it is designed for high RPM racing. Enduro racers typically get 12-13 THOUSAND rpms out of these engines. They have no flywheels and idle at over 2000 rpm. Even if you could get a torque converter for a KT-100, you would still need a tremendous sprocket reduction to get useable (slow enough) speeds.
Old Jul 29, 2001 | 10:02 AM
redrancher350's Avatar
if you want a new engine get it from northern tool and hydraylics.
btw, a 18 hp vangaurd v-twin should get that kart moving!
randycraft24c
Aug 5, 2015 02:50 PM
No2StrokeBs
Feb 22, 2004 09:20 PM
tbaws
Dec 27, 2003 02:09 PM
paul72
Jul 17, 2003 03:21 AM
