'01 Mojave: Anybody else have their carb blow off?
Old Jul 20, 2001 | 02:29 PM
rockrider's Avatar
I was starting my quad after riding to a gas station and it backfired and blew the carb out of the intake manifold. I loosened up the clamp, removed it, and fit the carb back on. The clamp was a real pain to slip back into place since it kept catching on a bracket.
This is the second quad I've had this experience with. The other time was on a '96 Wolverine way back in the middle of nowhere. I assume the backfires are caused by the lean stock jetting. Anybody know what jets I need to richen it up?
Old Jul 20, 2001 | 02:53 PM
madweazl's Avatar
Wow, thats never happened on mine (a '91). I've never noticed a backfire through the carb either. My Mojave was quite rich out of the factory (still is, never changed anything), I'm at about 130' above sea level in Yuma AZ.
Old Jul 22, 2001 | 09:54 PM
Mojaveracer's Avatar
That happened to my 2000 and '87 mojaves before. It didn't have anything to do with jetting and both happened while trying to start it up after being flooded. It's just a freek thing that happens rarely.
Old Jul 23, 2001 | 11:45 AM
madweazl's Avatar
Now thats something that seems to happen pretty frequently with mine, flooding. When I stand it up on the grab bar to work on it, it takes forever to start it back up. When I stand it up gas also leaks out somewhere on the engine, I cant trace it back but it almost looks like it comes out of the kick lever, any ideas on that one?
Old Jul 23, 2001 | 02:13 PM
cramman400's Avatar
it happened to my 01 mojave. I was so pissed off. I only had it a month. i was ready to push it over the hill. luckily i was around someone. they Took me back to Get my king Quad.
Old Jul 23, 2001 | 09:19 PM
2000MOJAVE's Avatar
I have never had that problem, even with a jet kit. Mine is a little more easy to flood since I took the pipe off and went back to the stock pipe, but there must be lots of fuel laying in your cylinder to blow the boot off. madweazl, fuel will run out at that angle. It will come out the overflow. Any carb will do that, they're just not designed to hold the fuel at that 90* angle. Just turn your gas off and run it out before you work on it.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Captjay
Jul 23, 2015 12:33 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
