Why is my Warrior hesitating?
Old Jul 21, 2001 | 12:10 AM
ridnwarrior's Avatar
The Warrior runs fine. Spark plug color looks good. When I ease the throttle on there is no problem but when the quad is idling and I punch the throttle it hesitates before it takes off. What could this be?
Old Jul 21, 2001 | 01:30 AM
Bartman's Avatar
Maybe it hesitates because it's scared. lol
Old Jul 21, 2001 | 01:54 AM
Blaster96's Avatar
Check the spark plug gap. Also i could be a bad plug. I almost bought a new CDI and Coil due to a bad plug w/ little to no gap and it sounds like the same thing that happend to me just on a smaller scale. Also mak sure your air filter is clean.
Old Jul 21, 2001 | 02:05 AM
YamaWarrior01's Avatar
A stock warrior doesn't have "great" acceleration as it is. If you hit the throttle too hard too quick it will naturally bog a little. Open the engine up a little with an aftermarket pipe and filter (jetted properly) and your acceleration will be improved.
Old Jul 22, 2001 | 12:20 AM
I was thinking it was an accelerator pump problem on the carb. Is there anyway to adjust the accelerator pump on the Warrior?
Old Jul 22, 2001 | 11:48 AM
pineman's Avatar
Yes! Bend the metal arm that has the little roller on it,till the plastic arm touches the plunger.It`s under the black cover on the left side of the carb.Also remove the rubber boot from the back of the carb and ck the squirt nozzle,to see if it`sprays fuel in the center of the carb.
Old Jul 26, 2001 | 02:07 AM
Blaster96's Avatar
NO. bending is not smart. The accelerator pump only kicks in at about 3/4 throttle. Also, check the air screw.
Old Jul 26, 2001 | 01:33 PM
Mr45auto's Avatar
If you lengthen the accelerator pump shaft (use a spark plug top with the hole filled in) it will significantly reduce the lag you experience. It accomplishes the same as bending the lever but wont damage anything.
Old Jul 26, 2001 | 02:33 PM
I'm thinking the hesitation is caused by a lean condition. Could that be true? The spark plug is only light, light tan. Not dark at all. Plus I'm getting a little popping sound when decelerating.
Old Aug 5, 2001 | 03:37 AM
Blaster96's Avatar
Yes it could be lean. If it is popping though the carb it is lean.
Reactant
Mar 30, 2022 02:08 AM
hueby
Nov 6, 2015 11:34 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
