warrior trouble
Old Aug 10, 2001 | 07:09 PM
TitanRacing25's Avatar
Hey guys, I'm having trouble with my 2000 warrior, i know the sylnoid is out, but I touch the two metal pieces to gether trying to start it, and it wont start battery is good and everything, what's wrong? sorry its so cauge, but I will give more info when asked.
Old Aug 10, 2001 | 08:56 PM
Mr45auto's Avatar
Check the fuse on the rear end left side. If it's blown you wont be able to start the quad. There is a spare fuse located right next to it.
Old Aug 10, 2001 | 10:16 PM
you are talking about those little white boxes right?
Old Aug 11, 2001 | 01:12 AM
Mr45auto's Avatar
No, those are relays. There is a wire with a rubber section in the middle, it is located near those relays. This section is directly above your spare fuse. Pull the connection apart and the fuse is inside, if this is blown your quad will NOT run. It will take about 5 seconds to see if this is the trouble and wont cost a dime.
Old Aug 12, 2001 | 02:25 AM
Blaster96's Avatar
When you blew the silinod you may have shorted out something. does it turn over or do anything when you connect the 2 leads?
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
