More Warrior mods/ Need more POWER
Old Aug 16, 1999 | 12:56 PM
RaceType's Avatar
Hi,
I own a '97 warrior ans have done the following to the motor
.430 lifted cam
stroked and bored to 400cc
pipe and carb
heavy duty valve springs with titanium retainers and new valves with a port and flow job
heavy duty clutch springs
je piston w/10:1 compression
What should I do next?
Thanks
Old Aug 18, 1999 | 01:43 AM
1BadWarrior's Avatar
How about putting a 14 or 15 tooth front sprocket
[This message has been edited by 1BadWarrior (edited 08-17-1999).]
Old Aug 18, 1999 | 04:08 PM
KevWarrior's Avatar
How much did it cost you to bore it to a 400?
Kevin JA Works of Georgia
1996 Yamaha Warrior
Old Aug 18, 1999 | 08:17 PM
RaceType's Avatar
Hi again,
To do the whole thing just bore it and stroke it cost me about $600 but if you do just that you will probably end up loosing power you should really get a new cam and valve springs and the list goes on but it is massive after you get done. I didn't think there would be this much more power from it but it is there.
[This message has been edited by RaceType (edited 08-18-1999).]
Old Aug 26, 1999 | 10:33 PM
Banshee1998's Avatar
The best way to get more power out of a warrior is sell it and buy a banshee. YOu get roughly double the HP out of the box and there are alot more cheaper proformance mods you can do to a banshee. I had 2 warriors then I got a banshee and I love it
Gabe Moeller
Old Aug 26, 1999 | 10:58 PM
TULLEY366's Avatar
I HAVE AND RACE A 98 WAROIR ON THING YOU COULD DO IS GO TO AN ALUMINUM SLEAVE AND HAVE IT NICASILED.ITS WORHT AT LEAST A COULPE OFF HORSES. PLUS YOU SAID YOU PUT NEW VALVES IN DID YOU GET OVERSIZED OR STOCK. WHAT CARD ARE YOU RUNNING A TM36-68 IS A GREAT CARB BUT IT GET PICK ABOUT THE AIR TEMP. THA WHITE BROS. 36 KIT IS ALSO A GOOD CARB. ALSO DID YOU KEEP THE STOCK HEAD PIPE? I'VE USED A DG HEAD PIPED WITH A SUPERTRAP IDSAND ITS GREAT. ASLO YOU DIDN'T MENTION WHETER OR NOT YOU HAVE AN OIL COOLER TI WELL WORH THE MONEY.
Old Aug 29, 1999 | 10:46 AM
RaceType's Avatar
First about the banshee I'll whoop all over you either way a wise man once said it's not how fast you go but how fast you get there! Second the sleeve I hadn't thought about I run a 38 mm Mikuni with a accelrator pump. and the valves are not stock sizes.
Old Aug 29, 1999 | 09:55 PM
Tree Farmer's Avatar
RaceType, your list of hop-ups sounds pretty comprehensive; I can't think of a lot to add.
Are you having problems with your engine? Why do you seek more power? Do you find your power output disappointing even after these extensive modifications?
Tree Farmer
Old Sep 1, 1999 | 04:01 PM
Heapster's Avatar
Well everyone, the long term 400cc Warrior project finally came to life
the other night, and am I ever impressed with the new power and throaty sound it
roars. Night and Day difference over stock. The improvement really is drastic,
and I'd highly recommend these Warrior modifications. The complete project took
almost 9 months,(my pace) and was worth the wait.
Specifics are:
.060 overbore and a 5.6mm stroker crank for 400cc (done at Powroll)
.430/.430 cam up from .380/.382 stock.
flow bench documented port and flow head gains of 10-30%.
Barnett clutch kit
lots of internal engine case bearings, shift rods and custom oil passage in
shift forks.
15/40 gearing
Supertrapp exhaust with Jet-Hot coated stock head pipe
Stock carb with K&N and holes in airbox.
Braided Stainless Steel plumbed Oil cooler.
Buffed satin finish engine cases with high temp clear coat.
<< I'm very impressed with the new found power, both in low end grunt torque,
a great mid range pull, and what seems to be awesome high rpm flow. Its what
I wanted, and pulls a larger front sproket and 15/40 gearing fine. >>
Heapster
400cc Wicked Warrior - 400ex Eater?
Old Sep 9, 1999 | 12:01 PM
RaceType's Avatar
I am not dissapointed with the power but enough never is.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
