Tecate owners...
Old Aug 12, 2001 | 03:22 PM
studboy's Avatar
my friend went out and bought a 1987 Tecate-4. Can a KX500
motor go right in those without to much modifications?? What
shops know their sh#@ about building those motors?? What is
the best pipe for those quads?? Is the motor the exact same
as a KX250 dirt bike of the same year?? If not will a KX250
dirt bike cylinder bolt on to a Tecate-4 bottom end??
Old Aug 17, 2001 | 05:46 PM
nacsracer40's Avatar
I'm not sure about your other questions, but i do know that LRD has a full exhaust system for the Tecates, its just not one of thier adjustable pipes.
-Dave
'86 250r
LRD national motor/pipe/silencer, AC pro pegs/bumper/grab bar, maier dark blue plastic, Nac's Racing graphic kit/seat cover/bar clamp/bar pad/brake block off/case guard/mud caps(beadlocks), marshall radial fronts on douglas .190's, grooved turfs on douglas/champion beadlocks, Tag bars, leagers a-arms/swing arm, LSR axle, anti fade lock nut, PeP rear shock, Ekla front shocks, GS Racing wireharness/chassis bolt kit
'01 Yamy Raptor
white bro's slip-on, razrs on the rear, AC nerfs, kill switch, turf tamers for racing.
'98 Yamy Blaster
fmf pipe/silencer, k&n filter, AC nerfs/bumper/grab bar, bandit rears on douglas .190's, fast trekker fronts on douglas .190's, renthal bars, injector block-off.
Old Aug 17, 2001 | 10:54 PM
imported_juggalo's Avatar
don't put the 500 engine in. you'll snap yoru frame because the engines not counterbalanced. the counterbalancer in my LT broke off. it shook a TON! and it also snapped my frame in 2 places. i couldn't imagine the vibration from an engine thats twice as big but i know your frame wouldn't last long!
Old Aug 19, 2001 | 03:11 AM
letitsnow's Avatar
I have an '88 T-4. The top end from an '87-'89 kx 250 will bolt on. If you use a kx 250 head gasket, check the compression, you don't want to be higher than 185lbs without using race gas. I don't know about putting a kx 500 motor in the frame. I have an FMF pipe, they work ok, but not great. If I were to do it over again, I would get the LRD pipe.
TecateRider
May 10, 2001 09:52 PM
Aaron10
Mar 29, 2001 06:06 PM
CALDS650
Mar 13, 2001 10:20 PM
scottbl99
Feb 10, 2001 12:06 AM
SandDraggin
13
Apr 20, 2000 02:07 PM
