HELP !! Banchee shifting problems.
Old Aug 25, 1999 | 07:10 PM
T's Avatar
T
I'm
Old Aug 25, 1999 | 07:23 PM
T's Avatar
T
I'm having problems shifting my 96 Banchee. I can go up in gears with no problems but the problem happens when I try to go down more than one gear at a time. When I try to go down from 4th to 3th I dont have a problem but when I then try to go into second I have to pull up slightly on the gear shift lever. Eg I can go from 1-2-3-4-5-6 with no problems but when I have to come back down it's 6-5-up-4-up-3-up-2-up-1. I changed the transmition fluid to a Bel-ray synthetic and the problem continues. My question is has anyone else had this problem and how did you fix it and what did it cost?
Old Aug 26, 1999 | 02:49 PM
350Banshee's Avatar
It sounds like you need to adjust your external shift mechanism. The adjustment is inside the clutch cover. When you shift the external shift mechanism engages the shifting pins on the shift star and drum. The actuator needs to be centered around the shifting pin (any gear except neutral). If it is off center too far it may be limiting the amount of movement at the shift drum so that it barely engages the next lower gear.
It is a relatively easy adjustment, but if you haven't already, think about buying the service manual it details this adjustment.
The adjustment is made by a off-center adjust bolt and a locking nut. Turning the bolt willmove the shift mechanism slightly so that it can be centered around the shift drum pins.
This is my best guess as to your problem, but the symptoms you describe point toward this adjustment.
Travis Bayne
<A HREF="http://www.geocities.com/Baja/Cliffs/3856/index.html">The Wrecking Crew Quadz Page</A>
Old Aug 26, 1999 | 08:09 PM
T's Avatar
T
Thanks!
I'll look into getting a service manual so I can make that adjustment. Appreciate it!
Tom Orsini
woodyinc@erols.com
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
