NEW BLASTER MODS
Old Sep 22, 1999 | 05:29 AM
BLASTER-00's Avatar
I BOUGHT A NEW 2000 BLASTER ABOUT
2 MONTHS AGO, AND I LOVE IT. IM
ALREDY STARTING SOME NEW MODS. IVE
GOT A FMF GOLD SERIES PIPE AND
SILENCER IN THE MAIL. ALONG WITH A
K & N AIR FILTER AND AIR BOX
VENTS. I WAS WONDERING IF ANYONE
WHO HAS DONE THESE MODS COULD HELP
ME WITH THE JETTING? THANX
Old Sep 22, 1999 | 01:17 PM
rottwolf's Avatar
I believe the rule is to go one pilot size for every mod and then go from there. You don't want to start out lean! You want to start out rich. Hope this helps.
Jason
Old Sep 22, 1999 | 06:37 PM
philzie's Avatar
I think Jason meant mainjet. My wifes blaster has the same setup as yours will and I am running 240 main, center needle clip position. You should go get some jets... 260 back down to stock (220 I think) I would start with 260 just to be safe.
Too bad the Blaster has that crappy float bowl with no main access. It sure makes dialing in the jetting a chore. That is why I got a new Mikuni with a jet access plug. Of course, I haven't installed it yet... :-)
Old Oct 25, 1999 | 06:10 PM
98'blaster's Avatar
ditch the k&n filter they make it easier for dirt to get in the carb and eventually into the motor get a uni filter
Old Oct 25, 1999 | 08:18 PM
yfs20099's Avatar
dont listen to him. you bought is so you cant just get rid of it. did you buy an outer wear? if not get one. also if you are taking the air box lid off get a cover that is made by the same company as outerwares and shockwears. as for the jetting i dont?
Old Oct 26, 1999 | 10:57 PM
Rocky's Avatar
My wifes 98 blaster has the same pipe and I have a 270 main jet. Alot will depend on where you are in the country I'm on the east coast. As for as the filter ordeal I have used both a K&N and a foam Pro Design on my banshee. I like the foam better but the K&N will work just fine. Either one you must keep clean, I have several and change them every 2 hours of riding sounds like alot but if you have more than one just swap and clean both when your home. Good Luck
Ahtatu
Sep 28, 2015 12:14 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1ArmBandit
Sep 8, 2015 08:59 PM
