front wheel studs?
Old Sep 27, 2001 | 12:28 AM
real4x4's Avatar
can i change them to longer bolts so i can run bigger tires?
Old Sep 27, 2001 | 01:52 PM
real4x4's Avatar
can this be done?
Old Sep 27, 2001 | 02:24 PM
modquad's Avatar
You can change them out with 3/8-24(thats the pitch, fine thread) Make sure they are at least grade 5.
KT
Old Sep 27, 2001 | 09:53 PM
Ronnnnn's Avatar
You can get sportsman rear studs to use in the front of scrambler/trailblazer or sport. they are identicle but longer.
Old Sep 28, 2001 | 01:41 AM
real4x4's Avatar
how would be the best and easiest way of removing the front studs??
Old Sep 28, 2001 | 02:26 AM
modquad's Avatar
Screw the nut on flush with the end of the stud, and give a few wacks with a hammer...brass one is the best. If you damage the threads, the nut will straighten them out on the way off. You can use fine or coarse bolts, just trying to save you $ with the fine ones, they work with the stock nuts.
KT
Bratman2
Aug 6, 2022 01:42 AM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
tporath
Jul 11, 2015 12:31 PM
