Roller clutch & belt problems....
Old Nov 7, 2001 | 10:37 PM
joyrider's Avatar
I think I might have messed up. Got a great deal on a used Hot Seat pipe and V Force reeds and they went right on. The folks at Hot Seat recommended their J1 weights and a blue spring. Again, no problem, the clutch work was easy and the performance gain very satisfying. Some of the guys told me I should put in a different helix and I think this might be where I went wrong. After a bunch of research I decided that Hot Seat's roller helix was the way to go. Installation was no problem but now I can't keep a belt on it. A new belt starts slipping in about two hours. By then it has stretched a bunch but even tightening it back to specs won't make it hold. Is the HPD rear clutch not compatible with the Hot Seat stuff up front? Should I be treating a new belt differently? The roller clutch really performed well, but I need more reliability.
I have checked for broken motor mounts, cleaned the pulleys when I adjust the belt, and talked to HPD for advice on spring tension in the clutch. Anybody got ideas????
Thanks for your help.
Old Nov 8, 2001 | 10:20 AM
modquad's Avatar
I'm assuming that there is a error, unless Hot Seat just came out with a roller clutch. If you talked to HPD, you did well already. Darrell and Mike dialed mine in, when I thought I was close, now I check with NASA prior to launches. Grab a notebook, and keep track of engagement, shift, and max RPM. Check your belt deflection. Tighten by removing shims between secondary sheaves, and loosen by adding shims. Tis' a good idea to pick up Hot Seats, or someone elses alignment tool. It's hard to diagnose clutches over the net, kinda like fixing a car over the phone, but calling the pros should get you in the ballpark. Hard motor mounts help also, depending on your level of mods. I may sound like a commercial at times, but once you have things dialed in, I strongly recommend the HPD Super Duty belt(Kevlar reinforced). These things really last, even with full race mod motor setups.
Good Luck,
KT
Old Nov 8, 2001 | 07:30 PM
joyrider's Avatar
Thanks. You're right the roller clutch is by HPD, but everything else is Hot Seat. I have it apart right now double checking. I think I might just need to check belt tension more. I will definitely look into that clutch tool. I will be putting on one of those Kevlar belts tonight.
Should be able to test it out this weekend.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
