Clutch problems on the Praire 650
Old Jan 3, 2002 | 03:28 AM
1BEARMAN's Avatar
Has anyone had belt or clutch problems on their 650? The belt on my wifes 650 wore out at 25 hours and was replaced under warranty. We were riding this weekend and a grinding noise started coming from the clutch area so we took it back to the dealer,as he was test riding it the belt hit the switch inside the cover and started running terrible. The mechanic sayed the belt deflection was out of spec and tripped the switch. The quad has a total of 44 hours on it and if this is going to happen on a regular basis its time for another machine. Has anyone else had any problems like this? Any help is appreciated
Bearman
Old Jan 3, 2002 | 04:27 AM
scootdog's Avatar
got about 40hrs. on mine with no problems, sounds like a fluke.
Old Jan 3, 2002 | 09:39 AM
kingmort's Avatar
I,m not sure, but I would think that belt deflection out of spec could only be caused by installing th wrong belt or serious clutch defect
Be sure to let us know what you find.
Old Jan 3, 2002 | 04:27 PM
jefffoxsr's Avatar
GOBOY,
How much snow can the 650 get through in 4wd?
How much in 3wd?
How much in 2wd?
Thanks.
Old Jan 3, 2002 | 05:21 PM
ConcoursQuebecCanada's Avatar
To GOBOY Are you sure that you have 400 hrs on your horodater it is not rather 40 hrs, if you have so much hours done I will keep my 650 for a long time, if this is right what is your mileage?.....I alredy change a belt after 500 miles.
Old Jan 3, 2002 | 06:46 PM
STAKK's Avatar
Had belt adjusted at 600 miles, 1200 now, no problem's remember if you ride it in high range all the time, or at low speed's it wear's the belt much quicker, or if you have monster tire's, expect to go thruogh belt's more often,heard from Kevin Staton who said a recall is likelt coming for the belt and clutch, but they are moving slow in that direction, save all your reciep's and repair bill's for a re-imbursement when the re-call comes.
Old Jan 4, 2002 | 12:00 AM
1BEARMAN's Avatar
Thanks everone for your oppinions, I will let everyone know how this mess turns out.
Bearman
Old Jan 14, 2002 | 07:50 PM
chop's Avatar
HOW DO YOU ADJUST THE BELT?MINE HAS SLIPPED TWICE BUT ONLY UNDER REALLY EXTREME TORQUE,PULLING ANOTHER BIKE OUT OF DITCH.IS THIS NORMAL OF A BELT DRIVE?THIS IS MY 1ST 4X4 AND IVE NEVER DELT WITH A BELT DRIVE SYSTEM BEFORE,THANKS.
Old Jan 15, 2002 | 01:24 AM
1BEARMAN's Avatar
I dont think it is normal for a drive belt to slip anytime unless it is wet. To adjust the belt tension correctly you must buy special tools [check the factory repair manual for part numbers] and shim kit. My wifes quad is still in the shop waiting for repairs but part of the fix has allready been completed. Kawasaki has released a factory update to stop the belt from triping the switch inside the clutch cover and will be performed at no cost to us. Kawasaki also extended my factory warranty for 3 more months.
Bearman
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
