things to lube and replace
Old Jan 20, 2002 | 03:32 PM
phaskell's Avatar
well its winter and i wanna lube greese and replace all the things i should before spring so my quad will be in top shape
i was wondering what you guiys recomend doing i was thinking of replace the shock bearings and the front wheelsbearings and maybe the axel bearing and lube the a arms any help would be great thanxx
Old Jan 20, 2002 | 06:52 PM
250rampage's Avatar
I suggest you pull out and grease the shock mounting bushings (both top and bottom), check the breal pads, check the rear bearings for play, check the axle locknut for tightness, and maybe pull out and grease the a-arm and swingarm pivot bolts.
Old Jan 21, 2002 | 09:34 AM
QUADMXer's Avatar
Don't forget to check the little things like brake pads, clutch and brake cables, etc.
Old Jan 21, 2002 | 01:43 PM
250rampage's Avatar
Oh yea, I almost forgot. Pull the steering stem bushing (top), and lube it up good.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
WilliamBos
Sep 30, 2015 08:08 AM
Rigit
Sep 29, 2015 03:02 AM
Wooodyii2
Jun 14, 2015 09:19 PM
DOAinNY
Jun 11, 2015 10:34 PM
