things to lube and replace
well its winter and i wanna lube greese and replace all the things i should before spring so my quad will be in top shape
i was wondering what you guiys recomend doing i was thinking of replace the shock bearings and the front wheelsbearings and maybe the axel bearing and lube the a arms any help would be great thanxx
I suggest you pull out and grease the shock mounting bushings (both top and bottom), check the breal pads, check the rear bearings for play, check the axle locknut for tightness, and maybe pull out and grease the a-arm and swingarm pivot bolts.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
