Missing Rubicon oil?
Old Jan 22, 2002 | 08:29 PM
earthraper's Avatar
Rubicon owners:
15 miles after purchasing my new Rubicon I was a quart low on oil. I topped it off thinking that it was low from the dealer. Oil level was ok up to 110 miles, I changed the oil for the first time.
It took a little over 5 quarts to fill, as the manual says it should. 35 miles later, I'm a quart low again.
I am running the motor for 5-10 min and then checking the oil (as the manual instructs).
It does not appear to be burning it or leaking it that I can see unless it is dumping some as I ride. I see none on the garage floor.
It's going back to the dealer in the morning. I was wondering if is anyone out there who has seen this too?
Thanks in advance
Old Jan 22, 2002 | 09:58 PM
TEXMud's Avatar
Have you checked your airbox for oil?
Are you screwing in the dipstick when you check it?
Old Jan 22, 2002 | 10:02 PM
earthraper's Avatar
TEXMud,
The airbox is clean and I do not screw in the dipstick.
Old Jan 25, 2002 | 02:23 AM
JRM's Avatar
JRM
let the engine sit for about 5 min after shutdown as the oil takes a few to sink into the tank or it will read low
95wolv
Sep 27, 2024 12:00 PM
tysonbully
Sep 28, 2015 02:30 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
