Adjusting Automatic Clutch on Recon
Old Feb 8, 2002 | 02:01 AM
Yarddog's Avatar
I bought my boy a used Recon (W/O Owners Manuel) for christmas for his first ATV. I think He has burned the clutch by starting off too many times in Higher gears other than first, even though I stay on him about it. I was wondering from some of yall with Honda's if there was an adjustment for the clutch and where and how? If it is gone How much are they? I bought it and the stock tires were wore out, so I put some Gators on yesterday and got on to try out and I could tell the clutch wasn't what it was. Any advise would be appreciated.
Yarddog
Old Feb 8, 2002 | 02:45 AM
Elrancho's Avatar
The clutch adjustment is for the 'change' clutch, the centrifigul clutch has no paticular adjustment. If it slips too much or engages wrong it needs internal work. A few abuses won't send the quad to the shop, but try to keep it in a gear where it's never slipping unless taking off to get going. IMO it's always better to rev up rather than be on the edge of slipping, case in point- putting at 6 MPH I'd rather be in first with the engine buzzing away than putting in second or third gear.
Old Feb 8, 2002 | 11:20 AM
tampavii's Avatar
I have recon dont know about clutch .But how did you like the gator tires on the recon .
What size did you install on all 4
Gene
Old Feb 9, 2002 | 01:29 AM
Yarddog's Avatar
Tampavii,
I put 22x10x9 on back, left stock tires on front. I like the Gators on the back. They tear up some ground: No more riding around the yard for my boy with these tires.
Old Feb 15, 2002 | 08:29 AM
Patto's Avatar
Do you still neet the clutch adjustment info ? if so I will try to scan it out of my owners manual...or if you can give me your email I will send it directly.. I also have the recon shop manual from honda..
Let me know
Paul
Old Feb 15, 2002 | 09:40 AM
trx450's Avatar
The factory manual is fairly reasonable, $40.00. You can buy it online for $44.00 to your door from: www.helminc.com
The manual covers all systems and repair procedures. It is easy to use. Laid out in a easy to understand format.
Good luck!
ghost civic
Jan 15, 2020 07:43 AM
peytonius
Sep 28, 2015 02:18 PM
MNatv89
Aug 10, 2015 02:20 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
MNatv89
Jul 7, 2015 11:36 AM
