2001 kawi 650 prarie belt slippage
Old Feb 10, 2002 | 12:28 PM
31259's Avatar
I recently went to Arizona to ride with my Dad in the Hope mountain's, he said that he had already had the belt replaced just before my arrival, we had'nt even put 100 mile's on this thing and it started squealling slightly again with a load. After talking to a couple of other 01 prarie owner's we found that they were having the same problem but un able to pin point the actual cause of the "defect". I'd like to know how many other owner's are having this problem and what information they have been able to get on the acual cause. thank'sTextnullTextnullnull[img]i/expressions/face-icon-small-mad.gif[/img][E=2001 kawasaki 650 prarie belt slippage]ok_marc_ok@yahoo.com [img]i/expressions/face-icon-small-mad.gif[/img][E=2001 kawasaki 650 prarie belt slippage]ok_marc_ok@yahoo.com
Old Feb 10, 2002 | 01:13 PM
Area51's Avatar
Did they make the Prairie 650 in 2001? I thought it was new for 2002. Sorry I don't have info on the belt slippage, as I just bought mine and only have 2 hours on it, but if it happens to me, I will let you know.
Old Feb 10, 2002 | 01:32 PM
Grizzjeeper's Avatar
650's started as 2002 models. If its a squak under load its probably just the belt deflection. Had mine reshimmed and no more squak.
Old Feb 10, 2002 | 06:08 PM
ConcoursQuebecCanada's Avatar
I have the same probleme at 500 miles my dealer change the belt and adjust the deflection and after a 1000 miles I still have the same probleme the slipperage appears in low gear,in high gear, and backward,but only for the first feet.I don't want to change the belt every 500 miles ? ?
Old Feb 10, 2002 | 09:36 PM
Canada:
Not sure if this helps, but I had to take mine in 3 times for them to get the deflection right.. Eveytime I gott it back it either squeeked louder or after a few miles it would start again. They started to tell me "they all do it and its normal" So I said I would not be back and was finding another dealer. Well they said to leave it for a week and guess what, its fine now. 700 miles. so far...
Old Feb 10, 2002 | 10:49 PM
31259's Avatar
I appreciate you sending me your "experenced" report I have a couple more question's.
Did the dealer not replace the belt or comment on it's condition? You see this is my Dad's 2002 atv and the dealer only replaced the belt which stopped it for a short time but did not mention any other replaced part's or adjustment's mad.
Also in hope Arizona where he does his most challenging riding there are believe it or not, three other 2002 650's they are beginning to have the same noise, and this is in the same RV camp where my Dad is!
I hope your atv's squak is gone for good and thank's for the come back.TextTextText
Old Feb 11, 2002 | 02:20 AM
1BEARMAN's Avatar
Hey Grizzjeeper
How do you like your dirtdevils? I ride mostly in the desert, no mud bogging. How is the ground clearance and did you loose any power? Thanks for the help
Bearman
Old Feb 11, 2002 | 09:22 AM
kevin_staton's Avatar
Over the weekend I heard that the supplier of the belts had the wrong angle on the sides of the belt (where it makes contact with the pullies) and that they were working on getting them changed. I would expect a recall on this IF IT IS TRUE.
Old Feb 11, 2002 | 11:46 AM
I beleive if they just changed the belt the problem will go away temporarily. if the deflection is off, as soon as that new belt breaks in you will hear that squak again. Thats what i have been told anyway. The dealer had to make a larger shim for mine to get it to stop.
bearman:
Dirt devils ride like glass, very smooth. No noticable powerloss. very flat better sliders than stockers. Lost gound clearance!!! 26 inch tires measure 24.5!!!
Old Feb 11, 2002 | 07:24 PM
1BEARMAN's Avatar
Thanks for the info Grizzjeeper
Bearman
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
buddieboy
Dec 9, 2016 05:50 PM
35dodge
Sep 29, 2015 09:40 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
