Sportsman rear shock adjustment
Old Feb 16, 2002 | 08:51 PM
Billyclub's Avatar
I want to adjust the tension on the rear shocks on my 500 but I am wondering if I need a special wrench to do it. Short of taking a big pair of Channel Locks to the adjuster ring what else can I use? Thanks in advance.
Old Feb 16, 2002 | 10:26 PM
samclow's Avatar
Billyclub,you dont have to use a spanner wrench to adjust the rear shocks,channel locks can be used A big set,but I would wrap the jaws with a rag or duct tape to keep from chewing the shock adjuster up.If you are going to adjust them and leave them alone I would think the channel locks would be ok,however if you plan on adjusting regularly I would pick up a spanner wrench from http://www.denniskirk.com/
Old Feb 21, 2002 | 01:51 PM
Deepcut5's Avatar
Billyclub, Check the tool kit that came with the quad. You can find it in your storage compartment under the seat. I have adjusted my shocks. There should be a tool for doing that in your kit. That is what I used.
blaze_master
May 26, 2015 11:18 AM
rhino99
Oct 2, 2000 02:44 PM
YellaTerra
Mar 30, 2000 04:38 PM
jbertch
Nov 6, 1999 07:07 PM
250rCanCan
Sep 20, 1999 07:48 PM
