prairie 300 4x4
Old Mar 3, 2002 | 08:13 PM
mazey's Avatar
bought a 2002 prairie 300 4x4 feb 5 it has 51 miles on it and the spark plug keeps fouling out. I was up in the woods and it would not idle and sometimes it would idle real high. Now the brake light stays on even though the brakes are released. it would not start yesterday but i got it started today. Will the dealer fix these problems even if it did get mud all over it, and has any one else had this problem with a kawasaki.
Old Mar 3, 2002 | 09:09 PM
robbieg's Avatar
it sounds like your running it with the choke on or it is possibly sticking. the brake light should be an adjustment. check the brake pedal there is a small spring attached to it for the brake light and it should all be covered under warranty. hope this helps you. rob
Old Mar 4, 2002 | 03:31 AM
DaveC's Avatar
Just remember to hand wash the fourwheelr before you take it in. They like to work on clean quads. I would get any bugs worked out before the 6 month warranty runs out.
Just for a piece of mind, my dad has over 3600 miles on his 99 300 4x4 and it still running strong.
Old Mar 5, 2002 | 11:33 PM
robbieg's Avatar
how did you make out with your 2 problems, did they take care of it under warranty.
Old Mar 6, 2002 | 10:48 PM
mazey's Avatar
hey robbieg, i took it to the dealer this afternoon they talked like they would cover it. They already found the problem with the spark plug fouling, the choke was stuck on. As for the brake light the dealer said they could adjust it. thanks for the info, i was afraid at first that i had bought a lemon.
Old Mar 6, 2002 | 11:20 PM
robh's Avatar
Make sure they fix the brakelight, mine melted cause i didnt fix mine in time and the bulb got so hot it melted rite through the housing, i got a pic of it if you want.
Old Mar 7, 2002 | 04:56 AM
dillas23's Avatar
The same thing happened to my Dad's Prairie. We noticied it during hunting season and just thought the bulb had burned out. After getting home we decided to replace it and noticed that it had melted the housing. The warranty was expired by then.
Old Mar 7, 2002 | 06:51 AM
REDBEAR4x4's Avatar
The light is not a new problem. I just ordered a full assembly for my bro inlaws 2000 prairie. You could smell his cooking while riding.
Old Mar 7, 2002 | 07:19 AM
robh's Avatar
I replaced my tail light with a led tail light for bout the same price of the oem light. And its looks great to boot. If you want to see a pic i got on i can post. Oh btw i had the same prob with the headlights too.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
