Clutch guard heat
Old Mar 10, 2002 | 02:22 AM
XtremeV6's Avatar
My brother found the key to my Scrambler and had some fun on it this past week. It seems like something might be wrong with the clutch, but I am also very paranoid about the quad. Today while riding, I noticed the clutch guard was getting got. I can't remember if it has alway done that or not. Does anybody eleses do that?
Old Mar 10, 2002 | 02:56 AM
modquad's Avatar
Since you have the 500, your clutch cooling outlet is already the larger one. Just some things I might suggest checking:
1) Make sure your cooling inlet isn't obstructed. This is under the nose piece. Just lift on the nose and it will pop off.
2) Pull your clutch cover off to inspect the belt for glazing and general component condition.
3) With the belt off, you can take some brake-cleaner on a clean shop towel and wipe both your primary and secondary faces of the clutches (the surface where the belt contacts. You can also use a little scotchbrite, or fine emery-cloth and scuff the surfaces, wiping them off with the brake-clean afterwards.
4) With compressed air you should periodically blow out your clutches (try not to breath the dust)
5) Your local dealer might borrow you there clutch alignment tool, or one is available from Hot Seat Performance. (hotseatperformance.com)
These are just some basics. I don't know your level of expertice, so my apologies if you already know this.
Good Luck,
Ken
Old Mar 11, 2002 | 10:29 PM
dcroc's Avatar
I've got a 500 Sportsman and never had clutch heating problems, Like the man says, check the ducts.
Old Mar 11, 2002 | 10:49 PM
XtremeV6's Avatar
So the plastic clutch shouldn't even get warm? I will check everthing this weekend to make sure. Thanks.
Old Mar 12, 2002 | 03:04 AM
modquad's Avatar
Your first post said hot....now you're saying warm. Warm is o.k. but not hot.
Old Mar 12, 2002 | 11:50 PM
XtremeV6's Avatar
OK, that was my fault. It wasn't so hot I couldn't touch it, but it was warm. I am planning on cleaning up everything on it this weekend so I will take a look at the cooling hose. Thanks again.
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
meddy0388
Sep 9, 2015 06:41 AM
poutlaw525
Sep 9, 2015 03:19 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
